for how long and to what pressure do people pressure test for?
16 Jul 2009
Hull
for how long and to what pressure do people pressure test for? Is a poly plumb and copper system.
18bar for 1 hour with polyplumb if i remember correctly.
Hep is 10bar for 1 hour.
Would be prudent to do a pre-test test at 1 bar to deal with any weeps ect, if any.
18 bar sounds alot I have a few copper soldered fittings on the system.
Do you test to 18bar? I was just going to go to 10 bar 18 bar sound high. Don't want to damage the pipework
yes i have tested at 18 bar before, it all depends on the manufacturers stated procedure.
heres a hep test i done last week at 10bar which is their procedure
Thanks and 18bar is ok for the soldered copper fittings I have on the system?
yes it will be fine, i believe the pressure is so high on pushfit as to ensure the fittings are properly fitted.
And you will definitely know of any leaks at that pressure :LOL:
thanks do you bother with any air removal when pumping up to pressure?
There should be no air whatsoever in the pipes during a pressure test
How do you get rid of all the air, without a valve on each pipe to purge it?
