I have a combi boiler, and on the bottom of it is a pressure valve that keeps clicking off and turning the boiler off, I just push it in again with my finger and the boiler works fine again, what keeps making the valve to keep clicking off.
...boiler make, model and what its running etc
it is not a pressure valve
I presume you are talking about a little button that pops out underneath, this is an overheat stat.
likely causes:
pump not working correctly
sludge or no water in system
poor circulation
blocked Heat exchanger
post some boiler details then we can help you properly
The make is: IDEAL RESPONSE 120
Yes you are correct, the little button underneath. Everything was fine, until we had a new heat exchanger fitted, and ever since, the button keeps popping out, and I have to pop it back in and on this goes. We keep loosing preasure as well, and have to keep topping it up. Any Ideas in what to do next??/
Thanks Steve.
No the boiler was working perfect before the repair..Any idea why this is happening,,dont want to keep forking out...many thanks.
woaa pull that hoss up boy
if it was working perfectly why was it repaired![]()
It's a response, one of the worst models from a bad brand....Any idea why this is happening,,dont want to keep forking out...many thanks.
