To move two upstairs radiators I drained the central heating system. Moved the radiators and started to refill the system, as I refilled the system building up the pressure and bleeding radiators the pressure release valve for the central heating system (not the valve on the pressure vessel) started allowing water out of the system and flooding my garage. Consequently I could not build up the pressure on the system. I was told that this due to an airlock in the system and that the water could not push it too the radiators.
I stopped trying to fill the system and cleaned up the mess!! To try and get the pressure up in the system I took off the pressure release valve for the central heating system and fitted a valve which allowed me to seal the system, I then repeated the process building up the pressure and bleeding radiators. Eventually no more air came out of the radiators and the pressure remained at 1 bar.
Can I switch on the heating system with valve that is sealing the system closed or could this allow too much pressure to build up in the system? If so could this pressure not be released through the pressure release valve on the pressure vessel?
Need some advice what to do next.
Thanks in advance
Thanks in advance
