Prevent bed slipping
13 Aug 2007
Liverpool
Hi.
I have wooden flooring in a bedroom and the bed has plastic feet, which mean that the bed tends to move slightly upon entering and exiting the bed.
Is there anything I can use, without marking the floor that will keep the bed in position?
i would cut a square off wood 150mm for each leg drill a hole in the center the size off the floor saver and use double sided tape to stick to the floor
lift each leg in turn locate the block on leg then drop the leg and stick to floor
Bit of double sided carpet tape under the feet will keep it still and easily removed with a bit of lighter fuel.
If you want to avoid marking the floor, screw the bed to the wall :lol: :lol:
