Price idea please
25 Jan 2014
Hi I have just moved into a new house and there is a spa bath in the that works but it is run of a 13a fuse spur on the outside of the bath room, which I have been told used to be a single socket
Now I have bought a rcd fuse spur to replace the existing fuse spur.
How much should I be looking to pay for a sparky to come and switch it over?
I have bought the rcd already so there will be no equipment costs
1 hour labour, at whatever the local rate is.
However this should be easy to replace yourself, it would be like - for - like
Yes I could do it myself but the wife wants someone in to do it!!
It's on the ring main, a socket was replaced for the fuse spur.
So there's a 32a mcb on that ring, but the CU Does have an rcd
Might be cheaper and easier to get a new wife.
Not a great deal of point in adding a RCD FCU to a circuit that's already RCD protected. An earth fault will simply trip both.
Also you'll have fun trying to find a spark who's willing to travel over to do a trivial job like this. It just isn't worth the time.
Not sure about that.
I think it more likely that the customer would be unwilling to pay the required amount.
Would you be willing to go quote for a job that the customer was unlikely to want to pay for?
I don't think I need to GO to quote for replacing an accessory but if YOU had and you're already there then you may as well fit the thing for twenty quid rather than leave having been told fifty pounds for another visit is too expensive.
[/quote]
[/quote]
Which is obviously why the previous owner did fit an unnecessary RCD FCU.
