- Joined
- 19 Jan 2008
- Messages
- 2,373
- Reaction score
- 431
- Country
If the pipes to either side of the rad are flexible for you to take the rad off its brakets them you can lift it up and put something under the rad to support it. Then shut the valves off undo the large nuts on the side slowly and lower the top of the rad down towards you and wedge that up with a piece of wood or a couple of bricks and tighten the nuts up and skim away loosen the nuts up when you have finished and put it back on the brackets. Put some rags or something under the valves before you open them (dont open them up too much just enough to bring the front down without the water ****in' out),, Good luck mucka, What part of Sheldon you from?
