- Joined
- 30 May 2004
- Messages
- 90
- Reaction score
- 0
- Country
I am replacing a corroded 100 litre hot water cylinder. The primary flow from a 2-port valve to the cylinder is via a 15mm pipe. The return is joined with 15mm bypass pipe & continues as a 22mm pipe.
As the new cylinder will be a 45 litre fast-reheat (muli-coil) design, would it be appropriate to replace the 15mm primary flow section with a 22mm section? I suspect it is an unecessary bottleneck which would reduce the new cylinders performance.
Any tips on removal/replacement of cylinders?
