I have a Primatic cylinder system with no hot water shut off valve fitted. I needed to change a hot water tap washer. I Shut off the hot water by opening a hot water tap then putting a tennis ball in the header tank outlet This was effective. After the job was completed I removed the tennis ball, then closed the tap. Everything seemed fine, until central heating was needed. The two upper most radiators are warm at the bottom, but cold at the top. I opened the bleed valves on both, but no air or water is expelled, they will not fill. Apart from draining and refilling the system, not a good idea in midwinter, any other ideas would be appreciated.
