Hello,
I have just joined this forum as I am new to DIY and will be doing it quite a bit from now on
One of my first projects is repainting a metal bed frame. I sanded it, cleaned it, then applied a spray primer.
However, I realised that the spray primer did not provide enough coverage, so purchased a one-coat metal paint and was old that a primer would not be needed.
I was told to sand the primer a bit, but doing so has made the surface smooth- not grippy. Should I stop sanding while I'm at an early stage?
Thank you in advance!
