I've bought a wall mounted tap (http://www.heatandplumb.com/acatalog/Sagittarius_Avant_Wall_Mounted_3_Hole_Basin_Mixer_Tap.html) It's one piece, has a plate attached for wall mounting, but there are no tap tails or connectors, just 1/2" threaded holes (vertical).
I bought 1/2" x 15mm male compressions couplers; they fit but leak - tried adding an o-ring on the couplier, then wound PTFE tape round the threads of the coupler, but still weeps.
What should I be using to connect this tap?
