problem sanding undercoat
10 Feb 2007
Kent
Hi all
I am repainting the front door.
i am usint dulux weathershield satin which says its self undercoating but I thought i would put a coat of weathershield trade undercoat over the (sanded) gloss.
I did this on friday and there were a few faults ( the odd drip mark, some bits on the door) so i tghought i would give it a light sanding.
the bits came off fine but when i sanded the drips (using 120 on a palm sander) the paint came off all sticky- the oly way i can describe it iis like when you remove a sticky lablle and then rub off the resiidue wiith your fingers)
obviously the paint wasnt totally dry.
I am now left with a patch rough surface.
whats the best plan of action?
should I just sand the lot of (using huge amounts of sandpaper as it clogs it up really quickly)
leave it for ? to dry and then sand it off
any advice is appreciated
if your in no rush just leave it for 3 to 5 days then id just put some under coat over the rough bit and rub i down so it belnds in with the rest
not in a huge rush but would like the whole job fished by next weekend.
do you reccomend repinting over the rough bits now ( it has the consistency of bluetac!) or waiting for it to dry then sanding it down and repainting it.
tempted to just put paint sripper on it and starting from scratch!
if the paint is still tacky then if you paint it now then the new paint is just liable to run patience is the answer lol
patience is a virtue...........
guess i will have to leave it until it sets then sand it to smoothness
sure paintstripper's not a better idea?
lol just creating work for yourself and it will still need a couple of coats anyway and you got to let each coat dry properly
BUt I am a man and thus no patience
the door is now stripped!! :lol: tomorrow i will sand an andercoat (very carefully)
wed i shall base coat the satin
thur i shall top coat the satin
fri i shall sit on the fron path with a huuuge beer saying " i did that"
more work less time......................
........................... i hope
