problem with a vaillant torbo max vuw 282/ie
9 Nov 2007
Middlesbrough
hi can anyone help i have a vaillant turbo max vue 282/ie when the heating is switched off or timed to go off after 5 minutes the yellow ignition indicator light flashs the boiler then wont work heating or water you have to switch the boiler on and off at the switch and then the yellow light stops flashing and the boiler works can any one help
there are a few lights on this bioler but i would suggest its the flow switch on top of the pump not operating correct if u use your instructions it should point u in the direction of the fault
Hi, i've got the identical problem with my Turbo max 282.
Has anyone found the cause/repair for this fault?
Thanks in anticipation!!!
Steve
Thanks, but no manual, but on my other combi boiler at old house there was a small plastic lever you could turn and it was very easy, but still stuck on this one :? :? :?
