We've got 2 showers, a pumped electric shower (has hot and cold feed) in the en suite, and a mixer tap in the bathroom with shower attachment. Hot water is supplied from a cylinder via open vented Y plan system, there's a cold water storage tank supplying the hot water cylinder and pumped shower only. Bathroom shower's cold feed is from the mains rather than storage tank.
Last night the son was in the pumped shower and came out and said the hot water had run out which I thought was odd. Thought nothing of it and got in this morning, turned it on, and it started coughing and spluttering and was very cold. No problem I thought, so I tried the shower in the bathroom, and it was fine when tuned to the right temperature through the mixer taps, but when you pulled the button for the shower it was very cold and next to no pressure.
Yesterday evening I was putting stuff in the loft, so went up this morning to see if I'd knocked anything or if there was a leak, as the pipework to the shower in the en suite runs along the loft surface (in climaflex), also checked the cold storage tank, the ball valve is dripping a bit but it is filling as it should.
Also yesterday evening, I noticed an Anglian Water van driving about our street (cul de sac) at around 7pm, looking for a house (I've done callout work before so recognise the symptoms!). I did think the cold pressure was slightly higher than usual so tried winding the stop cock in a couple of turns, this has slightly improved things in the bathroom shower, but I can't see how that would affect the ensuite pumped shower.
I am thinking the cold water is drawing into the hot feed through the shower/s, and maybe a couple of check/non-return valves would sort it, but it seems a bit strange that it's all happened suddenly and worked fine yesterday morning. Or is this all just a massive coincidence and I'm over thinking things?
Many thanks in advance
