    Dismiss Notice
Problem with discharge height of toilet
Discussion in 'Plumbing and Central Heating' started by dunc, 31 Oct 2006.
  1. dunc
    dunc
    19 Jun 2005
    30
    Thanks Received:
    Country:
    I have put a shower in a downsairs toilet. The soil pipe was cut off at floor level and a new 100mm connector fitted with a 40mm side inlet. Into this went std 100 mm T and into T went pan connector.
    Trouble is that the pan connector [about 450mm long] now slopes up so the T end is about 30mm higher.
    Is this a big problem or will it work OK.
    Thanks.
    Dunc
  2. Sponsored Links
  3. sime10
    sime10
    19 Oct 2006
    792
    Thanks Received:
    6
    Cardiff
    Country:
    Not good practice you will get blockages (never taken a soil or waste pipe uphill myself) but you are looking for trouble and wet feet
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
