Hi everyone, I've got a query!
I recently decided to do a mains flush on my central heating system (pumped system, worcester bosch boiler) as per the excellent instructions on this site.
It all went fine downstairs with mucky water then finally clean from each rad, but upstairs was a different story. Basically I couldn't get any flow down the flow pipe to the drain point from the upstairs radiators, and I eventually realised that something (other than a possible airlock) was blocking the flow back down the flow pipe from upstairs.
On uncovering a removable tile in the room with the boiler I found the flow and return pipes to the upstairs radiators, and the flow pipe has a strange looking bulky valve fitted inline, with a screw adjustment (which is actually leaking a tiny bit).
I looked through posts on here to see if I could ascertain what it was, and it seems that it could be a one way valve, but it also seems one way valves are only used on pumped heating with gravity hot water to prevent the rads warming up when the hot water is on(?) but I'm sure our heating and hot water are both pumped (I'm reasonably sure I can hear the pump start up for both heating and hot water demand).
Is it possible the valve is left over from a previous install (I'm not sure of the system history only that the current boiler dates from 1994)?
Anyway getting to the point, I really want to flush the upstairs rads and now I've found the valve to be leaking I'm wondering if I can simply remove it altogether to facilitate this. Can anyone think of a reason for it to be there?
Just FYI, there's 10 radiators in total, 5 upstairs and 5 down, and when operational the entire system works fine.
cheers
cheers
