We are having a problem with the central heating I'll try and describe the symptons.
1) Boiler make / model (gas or oil)
Potterton PrimaF / gas
2) What is / is not happening.
If the programmer is set to turn on the heating and hot water at the same time the water gets hot but one of the radiators downstairs remains cold.
I can see the CH and DHW lights LEDS are on. I suspect the Circulating Pump isn't working.
If I turn the hot water off on the programmer (just the CH is displayed on the Motorised valve) this time the pump seems to activate and heat all the radiators.
3) Has ANYTHING else been done or changed recently.
Nope being doing this for as long as we've been in the house (2 years)
4) When did the problem start?
when we moved in
5) When does it happen? eg, heating coming on or going off.
See 2
6) Anything else you feel may be of relevance.
see 2
I'm not really sure what's broke here can someone help. I will provide more inofmraiton if it'll help.
Mark
when we moved in
See 2
see 2
Mark
