My first posting although I have followed this excellent forum for a long time.
I have what I think is called an "open" system (Not a combi boiler).
The boiler is old but seems to work fine.
The radiators are on, but the only way I can get the radiator in the bathroom on (which is on the hot water system, so that it works in summer), is when I turn up the thermostat on the hot water tank, so that it calls for more hot water for the indirect heat coil in the tank. It then heats up the radiator perfectly, but later goes off again, I assume when the hot water tank has reached the new temperature.
Possibly a red herring, but last summer I drained the system to put in TRV's on radiators.
Is this likely to be a problem with my motorised valve? - It has three ports (I think, it looks exactly same as the one under item 10 in FAQ) and so if this is the problem, I assume I have to replace the whole valve and cant just change the electric motor on this one?
Many thanks
Many thanks
