Problem with my combi boiler pressure
14 Sep 2005
Hello
I have a problem with my boiler. Its is a combi boiler which I have had for nearly 6 years. Recently it has decided to loose pressure and drops so low that it won’t fire up. Also recently when I attempt to use the hot water it will not ignite but if I turn the thermostat on the central heating it fires up correctly.
Most recently it has began making a hissing or wining type noise, which comes and goes as the boiler is on. Also there is water escaping from out of the overflow pipe outside.
Does somebody have an idea on what’s wrong with it and how much it will cost. Also I’ve had the boiler for over 6 years and do you think I need to replace the unit with a new one. It still looks quite modern though but looks can be deceiving.
:D :)
Shab
First thing is to replace the pressure release valve and maintain pressure, then see what problems if any remain.
Hye
I've had the pressure valve is fixed and it now maintains pressure. my next problem is the fact that sometimes it doesnt fireup when i turn the ttap on, but when the central heating is started it fires perfect. But this happen occasionnally. At the minuate its ruinning fine
Any one have any ideas????
Thanks gasman so far
