I've just had a new mixer shower fitted. The problem is that the hot and cold water mixes well through the taps but as soon as you switch to the shower it's freezing cold, I've basically discovered that if you turn the cold water tap on at all the shower runs as cold water only.
The header tank is in the attic and the hot water tank is on the landing, same level as bathroom. Both the hot and cold water comes from the mains - does anyone have any ideas please? I don't really want to just turn the heat of my hot water down and use this only for the shower as the pressure will then not be very good.
