I'm due to have a new kitchen fitted and I'd prefer that the hot and cold water pipes are moved to the corner to be boxed in and a bit less visible. The corner will have a wall cupboard fitted on the wall on the left side of the picture below.
Now I have the floor up upstairs, I'm struggling to work out the easiest solution to achieve this.
Where the pipes start to drop down the wall it doesn't look possible to get in behind to fit compression joints or solder in new elbows.
I could cut this side of the floor joist, but then would miss feeding them down the corner, unless I cut a hole back through the joist. If that makes sense!
Wondering whether plastic pipe would work easier too than copper.
suggestions for a good solution would be welcome!
