- Joined
- 11 Jan 2004
- Messages
- 46,457
- Reaction score
- 3,768
- Country
Especially if it then catches fire...
Because that is what it says in my BS7671:2008
If your tumble dryer takes several hours to do a load, you should get a new one.And a tumble dryer may be running at full load for several hours continuously. It's the nastiest load in the typical house from that point of view.
Depends on model but some are designed that way. OK would be below 2 kW as that is the whole idea long time and low watts, but Joules used per cycle are less than the hi heat models designed to be used with off peak power. All the spec about them shows they are better than the fast models, some do still have the option for a fast dry.If your tumble dryer takes several hours to do a load, you should get a new one.And a tumble dryer may be running at full load for several hours continuously. It's the nastiest load in the typical house from that point of view.
I have had the argument before as to if the appendix is part of BS7671:2008 and the answer is simple are you tested with questions from the appendix when sitting the C&G2382 answer is yes, so clearly it is part of the regulations. However be it a recommended method to prevent overload of or a regulations does not really matter, even the regulations are not law, it clearly suggests the like of washing machine, tumble drier, dish washer, and oven should not be on the standard ground floor ring.Not as a regulation. In the BRB (BS7671:2008) it is also an informative Appendix 15. It gives four suggested methods of reducing the effect of using current carrying equipment for long periods on a ring final.
Another is locating socket outlets to provide reasonable sharing of the load around the ring.
Nobody is saying that it is not "part of the regulations". Anybody with a copy can see that it is part of them on p453.I have had the argument before as to if the appendix is part of BS7671:2008 and the answer is simple are you tested with questions from the appendix when sitting the C&G2382 answer is yes, so clearly it is part of the regulations.
No it doesn't.it clearly suggests the like of washing machine, tumble drier, dish washer, and oven should not be on the standard ground floor ring.
Surely that would result in the same situation.Since a new house one would assume it would have a dedicated laundry ring or kitchen ring!
It advises that those, and immersion heaters, space heating and loads of a similar profile not be supplied via a ring.Appendix 15 only stipulates cooking appliances over 2kW (only 8.3A).
Hi All,
They have found an issue with the downstairs sockets ring between a socket in my living room and a socket in my utility room (which are at opposite sides of the house).
SoYou cannot have a dedicated socket circuit.
Dedicated means designed and installed to supply a certain item or certain items of known loading.
if it can be dedicated to lighting, then why not dedicated to kitchen use?740.55.7 Socket-outlets and plugs
An adequate number of socket-outlets shall be installed to allow the user's requirements to be met safely.
NOTE: In booths. stands and for fixed installations, one socket-outlet for each square metre or linear metre of wall is generally considered adequate.
Socket-outlets dedicated to lighting circuits
(b) a specific labelled or otherwise suitably identified socket-outlet provided for connection of a particular item of equipment.also seems to say a socket can be dedicated. OK I know this is old version of BS7671:2008 and talking about a special location but it does seem to point in being able to have a dedicated socket circuit.
740 relates to temporary installations at fairgrounds etc. (in my BYB - is it the same?).if it can be dedicated to lighting, then why not dedicated to kitchen use?
Isn't that the wrong way round for items on a dedicated circuit? Although I suppose it is covered by the "safely" at the end.An adequate number of socket-outlets shall be installed to allow the user's requirements to be met safely.
Is it not possible to plug in anything else?also seems to say a socket can be dedicated.
Not really. Would it be possible to plug in some extra items?it does seem to point in being able to have a dedicated socket circuit.
