Problem with Worcester 35CDI
26 Nov 2012
Kent
Hello
I was wondering whether anyone can help me please?
I've recently brought a repossessed house which has been empty for the past 9 months or so.
It has a Worcester 35CDI boiler fitted. I hired a local gas safe registered plumber to recommission the boiler and fit a few new radiators. He 'successfully' fitted the new radiators, then whilst firing up the boiler he managed to flood two rooms, where one of the valves was undone and another was left off completely. As you can imagine my confidence in him has dropped considerably - though there appears to be no damage.
Anyway, eventually the boiler started and the central heating is working - however we don't have hot water working. He mentioned that the diverter valve in the boiler must be broken. When the hot water is turned on, apparently the hot water light is supposed to be on when running the hot tap - but its not. After he left, whilst running the hot tap, I got the occasional warm patch, whereas the water was usually as cold as the cold tap. However this was only the very odd rare burst.
Does the above sound like a diverter value? If so, would it need replacing or just a bit of well placed wd40?
Thanks for any help.
Jamie
If you have a 35CDi, then there is no diverter valve. The CDi II has a diverter. The original model has 2 pumps fitted, much like the older Worcester 350. If the demand light is not illuminating when you run a tap, I would suspect the flow switch may be at fault. First things first though, check which model you have.
Hello
Thanks for the prompt reply. Thinking about it, I'm pretty certain its a CDI II. Sorry for the confusion!
Thanks again
Jamie
I'm not sure whether to try to get a gas plumber to fix it or to pay Worcester the £300, for them to repair it and support it for a year.
