replaced pump in airing cuboard,which had a leak and fused electrics,now rads down stairs stay cold, up stairs does get hot but boiler(an ideal)cuts out.rads are all original ,no TRVs,except bathroom which is a mess and has no bleed valve so have been cracking top nut to relase air. have bled all rads several times but still think there is more air as there is noise from pipes above boiler before it cuts out.
new pump seems to work fine but does get hot.
drained system to replace pump.
when bleeding rads there seems more pressure upstairs than down.there is a little heat getting to the feed pipe to 2 of the downstairs rads but not enough to heat them.
Any ideas?
Any ideas?
