I am currently having problems with my central heating system.It all started with a few radiators had stopped working.I drained down the system and removed all the radiators and flushed them.I also flushed the system out with chemicals.I refill the system and it works ok for a few days but boiler was tripping out and indicated pump fault or air flow fault.Also i was having problems with 3 way diverter valve and i have replaced with a new vavle but is still causing problems.I have also fitted a new pump.I have bled all the radiators and the air vent next to the boiler.I have had a plumber come out to look at it and suggested i fit a air vent on the fed pipe coming out of the boiler.At the moment i have the bypass vavle open but still unable to get any flow arond the boiler and the hot water is going into the fe tank.
I also tried refilling the system from bottom to top as well and fitting a hose to mains water to try and clear any air blockages.
As any one got any ideas what could be wrong and how i can get the system back up and working.
