Problems with replacing electric shower unit
27 Jul 2007
Replacing a Triton Jade which has a inlet pipe which is not hidden - just goes up the bottom of unit and attached to wall.
Looked in B&Q and saw no units where inlet pipe is like this. None of them had inlet hole - just hole for shower hose.
Call me stupid as ones in B&Q on box said inlet is either top, bottom or rear - am I missing something or on these ones do pipes have to be behind wall?
Where can I get a unit like the Triton Jade? Where inlet pipe is visible and goes up the bottom?
Cheers
Rich
Ok stupid :wink: , rear is through the wall, bottom is what you've got now, so it should be more or less ok
if it said the shower has top, rear or bottom entry then it has.
the ones you see probabley had the blanking plate in so you wouldn't see the hole anyway.
