The post was about possible causes of the Sandtex product doing what it did. It was not about looking for advice on applying a paint product.
When you have no information on what brushes or applicators I may or may not have used you have no reason or justification whatsoever to comment on this in a derogatory way. I use Purdey brushes for applying emulsion and a middle of the road Harris brush for oil as I usually dispose of them after painting. A mini roller is something I've rarely used having not covered larger areas very often with oil paint but was bought from my trade counter as I assume many decorators do use them often.
No one here appears to have a lot of sympathy for the problem I suffered after quite a bit work and preparation. Hence any further comments judging or jumping to conclusions are therefore quite unwelcome.
The forum however has been generally very helpful in general and the help has been appreciated by me.
Thing is, the americans (contractors) would spray and laugh at us for using a brush so we all have our preferences and no point getting high and mighty about our preferred 'weapon of choice'.
Yes indeed, thank you. Also has little bearing on my posting hoping someone might have had suggestions on successful use of Sandtex's eggshell Xtra for exterior work
