A friend has no gas to his small flat. It's in Abroadland, so he has electric water heating via a 100 litre tank and a 1.5kW immersion heater.
He wants to install a 6kW electric flow boiler, but his electicity supply limits total power to about 7.5kW. Clearly if the HW is on (1.5kW) and the CH is heating (at max 6kW) too he will be running close to the trip limit. Add a microwave oven in use, or kettle, and nuisance tripping will be common.
I want to measure the input current and switch off the CH when current approaches 30 A (by switching to the 'temperature satisfied' teminal of the boiler. However the problem is that, once the boiler's heaters turn off the load will reduce greatly (by up to 24A), clearly setting up a condition where the 'OK to turn the heating back on' threshold is reached, and an ON-OFF cycle will ensue.
What I need is a relay that operates at the 30A level, but delays resetting itself for a period of time (enough time for the kettle to boil, say), and has variable hysteresis.
The measurement of input current will be via a current transformer giving 1vdc for 50A ac input.
A bonus function would be the ability for it to switch remote sockets off, such as when his gf overloads the system with a 3kW blower heater and hairdryer in the bedroom!
Any ideas?
Any ideas?
