protecting / painting wpb plywood for outside
27 Jun 2005
i am remaking a box on my trailer out of wpb ply because the last one has shed its skin and is falling apart after only a couple of years!
what covering and process would you use to stop the ply falling apart and keep it lasting a lot longer
thanks
Marine ply would have been the ideal choice but failing that then prime , undercoat and gloss should do the trick. I'm actually going to refurb my own trailer and I'm using wbp as well because I've got it for free and I'm basically too mean to buy marine ply.
It may be as well posting this in the decorating forum or asking the mods to move this thread.
thanks for the reply, i did post this in both forums because of different experiences of ppes working with paint and timber
marine ply was far to expensive i need 6 sheets in total and figured provided it was better protectectd it would do the same job, the last one was painted with undercoat and the then black gossed looked really good but didnt last long! used wickes paint ,maybe need ed more coats only done 2 unders and 1 gloss
Epoxy resin is about the most weather resistant coating you can apply. If you fillet the corners too it'll add some structural strength.
I'd give it three coats of west systems epoxy and then cover it in a 2 pack polyurethane top coat. It'll last forever as long as the coating is applied front and back and remains intact.
