Protecting plastic pipe though metal stud walls
4 Apr 2010
Humberside
As the title what do people use to protect plastic pipe when threaded though metal stud walls?
Cover it with a larger diameter pipe. You could use small lengths cut lengthwise on one side so you can snap them on once the smaller pipe is fitted.
How do you stop the larger pipe I was thinking of using 20mm conduit. From moving? Clip either side of it?
