Good morning,
A bit of background first then ill try and explain the problem. At the inlaws house they dont have the conventional combi boiler or even a tank, what they do have is the main cold water supply coming in in the bathroom, this supply feeds the toilet next to it which is t'd off the main, the main then feeds an electric shower and then onto the bathroom under sink unvented water heater and then into the kitchen where it feeds another unvented water heater for the kitchen sink.
The problem they are experiencing is the PRV on the water heater in the bathroom, its a 6 bar prv as specified by the manufacturer, its a Crown CPU10 heater. What happens now and again is that prv opens and closes with extreme speed making the heater jump around and the pipes sound like a jack hammer. The only way to stop this carrying on is to turn the main supply virtually to nothing.
I nipped round there yesterday and had a look at the PRV being that it was only changed 2 months ago for the same reason, i took it off and opened it up to check it to see if its seating properly or was full of carp but it is in perfect condition. Put it back on turned the water back to moderate pressure and then manually opened the prv at this point it got stuck again, the spring jumping up and down like a lunatic pipes banging - back to square one.
Nowhere on this 1 pipe system is there an expansion vessel but tbh im not sure why im mentioning it.
I am trying to get a plumber round again but the good ones are always really busy.
I have some plumbing knowledge but this is beyond me could you help please??, Thank you.
