Hi, after a little help with my patio door. First off i'm trying to find the proper name for it. You pull the door towards you and then slide it to open.
I'm after some spares for it as its starting to have problems locating when you shut it. I'll add some pictures to try and help describe it.
When you slide it shut, it has a locating pin that collapses the hinges and the bottom of the door closes to the frame, then you push the top to the frame then push the handle down to lock it. The locating pin seems to be hitting the top of the stopper and not locating in it. Still with me? I found a small broken collar that i think sits around the pivot pushing the pin closer to the locator. Because it has broken and fallen out the locator pin is not lining up. The only way i can see of fixing this is a whole new slide/hinge/locator hardware on the bottom of the door.
I suppose i'm really after the name for the style of door, or if i can even get spares for it. I really can't afford a new door at the minute.
Heres some pictures>
