I have a Grundfos alpha+ 15/50 pump which is making a pulsing noise intermittently when in the variable speed setting (which is the setting it was set at when i bought the house, and not making any noise up until last year) it runs for about a minute smoothly then starts pulsing annoyingly for a couple of minutes, i have tried alternating C/H and H/W and it pulses no matter what is using the pump. The system is 4 years old.
Just by trying a few things and switching the pump to the opposite settings of 1 2 & 3 of which i set it at 2, i found the pulsing to stop and pump to start flowing smoothly again.
I recently bought a new pump and replaced the one that was there but i get the same problem, so i guess its not the pump?
Am I causing any damge to my system by leaving my pump on this setting? I have noticed a juddering noise coming from the motorised valve that goes into my tank when i use the no.2 setting.
Sorry if any of this is confusing there is a pic of the pump and valves in my album if it helps
thanks
thanks
