Puma
18 Feb 2006
After running D.H.W and boiler shuts off overheating occurs steam from a.a.v etc and o/heat stat kicks in :?:
I take it that you've checked the dhw flowswitch and microswitch are operating correctly?
clue (not sticking on).
If you read the post.......This occurs after the boiler has shut off i.e micro switch disengaged, :roll: burner off,the residual heated water seems to boil.
I have opted for heat x,any other ideas. :roll:
I'd guess the same, considering they don't boil if the pump isn't even running, so it isn't a flow thing.
Thea GV is shutting smartly I presume, & not over gassed?
A load of trapped air in the primary side (now that the heating's not being used)..change the aav/run the heating?
New heat x job done,Pox and baxpots you really must read the post before crashing in with assumptions.
Thanks all
