Hi all,
I have a Ravenheat combi boiler that developed a fault over a month ago. It stopped working and found out that the pump capacitor had developed a crack. The original capacitor is a 2.6 uF, I replaced it with 2.5 uF as that was the closest I could find locally. It worked fine for over a month then the boiler started tripping the RCD whenever it is operated. I located the fault to the capacitor again. However the capacitor looks fine externally. I replaced the capacitor once more but the problem reoccured after a day.
I wonder what the problem could be?
any help or suggestion is very much appreciated.
