OK, you have two zone valves, a Honeywell and a Drayton. The Honeywell should say V4043H; can you confirm this? It sounds like an "S-Plan" arrangement, but the Drayton Valve is designed for a C plan. This does not matter, provided the valves are wired in correctly. It would be helpful to know which wires are connected up for both valves. It does not matter, at this stage where they are connected.Hi, both are attached to the pipework. The Honeywell has a number stamped on it of 272848. The picture you have is of the other, the Drayton, is exactly the one I have. The problem seems to be very intermittent. The pump was on all last night, as would have been the boiler had I turned the thermostat up, but corrected now, presumably as the programs kick in?
Here is a diagram of an S plan:
The wiring should look like this:
Post you photos to a free sharing site, I use www.tinypic.com, then copy and paste the IMG address they give you into your text. The picture will appear like mine above.Sorry, I don't think I can add the snaps I've taken !
