- Joined
- 19 May 2014
- Messages
- 3
- Reaction score
- 0
- Country
Not sure if this is to be expected or not - either way, it's only just started doing it and the only thing that's changed recently was I turned the ch room thermostat right down as we don't need ch at this time of year...
so what we've been finding is that at bedtime when both ch and water timers have been off for hours, there's a new humming noise from the airing cupboard where the hot water cylinder and the main pump/valve gubbins lives. When you feel the pump, it is vibrating quietly, and when you move the speed switch up from 1 to 2 or 3, the humming gets much louder.
So what's puzzling me is why is the pump pumping at all when the timer is telling it that the ch and water heating functions are both off?
If it is supposed to do this, what is it pumping and why? More importantly, how can I stop it humming at night, as it disturbs our sleep?
If it is not supposed to do this, what are the likely culprits and how can I test for them?
I tried turning it off and on again at switch near timer (which did work in our old house when we had ch off in the summer!) but no luck - the humming resumes as soon as you switch it back on.
Only been in this house two months, so this might just be something we've only discovered for the first time and that's perfectly normal I suppose??
It's a normal modern low pressure (?) system - boiler (non-combi) in garage, hw cylinder in bathroom....
All help appreciated
