as long as your PRV will adjust low enough to match your hot pressure then yes it will
if you use the pressure equalising valve it will adjust itself to match pressure , this will give you exact equal pressure all the time...you probably wont get this from just PRV on cold
PRV will work , just not the best fix is all
also if at anytime someone puts a pump on that hot supply (or fits unvented) you will still have equal pressure
whats the flow/pressure like on this tap on the hot side ?
Chris
Chris
