Puncture repairs
using a drop of brake fluid
Dish soap would probably be better; not as aggressive/risk of damage to alloy coatings and valve rubber (unless I knew for certain that particular kind of brake fluid and the rubber the valve is made of are compatible, I would hesitate to use it..) but all in, nice one!
I used to teach tyre fitting years ago. Dish soap is not ideal to use because some of them contain a small amount of salt and is not ideal to use when fitting tyres as it doesn’t contain any corrosion inhibitor. When a tyre is removed, if there is corrosion (and air leaks) on the bead seat of the rim, it’s always because dish soap has been used. As I had no proper bead lubricant, I just used a drop of brake fluid as that will not cause corrosion to the rim or damage to the rubber. If brake fluid damaged rubber, we'd all be in trouble!
On my scooter and bikes I've always used vaseline, especially to help the tyre pop in position when inflated.
Wrong?
The thing is, there isn't just one brake fluid, and there isn't just one rubber.. The rubber used in brake lines is obviously compatible with the stated kind of brake fluid on the reservoir lid
I've a big syringe that I use for applying vacuum when bleeding bike brakes, and the brake fluid has attacked the seal in that, expanded it and caused it to go soft. It doesn't matter for the purposes I use it for, but I wouldn't use brake fluid as a lube on a rubber I wasn't certain was resistant to it. Tyre valves don't need to be thus because they aren't in contact with it..
You say it with such certainty, like you can look at a tyre that's been on rim for 4 years and concretely declare the presence of fairy salt having rotted the rim. I reckon that's cobblers, argument for the sake of online argument, when you know full well that alloys routinely have hammer on weights applied when they shouldn't (your own pic features such) damaging the powder coat, tyre monkeys stabbing too-sharp levers into places they shouldn't, user kerbing etc and they're routinely driven on roads literally covered in salt
"It's because of dish soap"
OK. I amend my previous advice; do it properly and use tyre soap, or a bit of tyre slime, bead sealer or something knowingly fit for purpose
From memory, they make DOT3, 4, 5 brake fluid, and you have to use the correct one, for it to be compatible with the rubber seals used in your system. How that affects using it to fit tyres, I have no idea.
How else would the moisture/salt that causes corrosion get between the tyre bead and the rim unless it was there when the tyre was first inflated?
….you know full well that alloys routinely have hammer on weights applied when they shouldn't (your own pic features such)
Very rare for alloys to even be able to take a clip on weight these days and even in the old days with alloys with a lip on them, they went nowhere between the tyre bead and bead lip - they couldn’t have as they would have leaked. The clip on weight on my wheel is O/E and nowhere near the tyre.
DOT5 is silicon based and hardly used - certainly shouldn’t be mixed with any other fluid. I’ve never used it. Ever. DOT3, I haven’t seen for years. Which leaves DOT4. Virtually all rubber used on a car is EPDM.
Sleep easy lads. (y)
Wrong?
Silicone lubes are always much safer for anything rubber or nitrile (eg. o-rings). Vaseline isn't recommended. Not sure if silicone lubes are recommended for tyre fitting applications though.
Any science behind it?
My thinking: vaseline is safe on our skin, why not on tyres?
