I'm reading that PIR/ PUR foams lose their efficiency over time due to the gas contained within the bubbles escaping to atmosphere. How much can we expect the efficiency to drop off by after 5 years?
Plain old fresh air is one of the best insulators we have - most insulation technologies from the clothes worn by a polar explorer through polystyrene foam packing in the ice chest that keeps transplanted organs cool, to the fur on your cat is simply the trapping of air. Trapped air insulates
A 4 inch kingspan board would not only have to lose all the bubbles in the foam, but collapse to form a dense solid with no air gaps too..
I'm betting the good ole guys at Kingspan and Celotex may have done a tisy winsy bit of research and development and have had to satisfy governing bodies like BBA in order to get a licence to sell these products.
My guess is that bubble gas loss may be a (rather weak) attempt at kidding the fools....?
The reason the foam is so efficient is that the bubbles are actually full of a gas (blowing agent) this is denser and better at insulating than standard air. There have been a few scientific reports that state that the insulative properties of PUR foam etc drop off by about 20%within 2 years as the blowing agent in the bubbles is leached to atmosphere and replaced by air.
As DIYedboy;
there was a report produced in 2006 by the -wait for it - Federation of European Rigid polyurethane foam Associations, which stated the following;
the insulation characteristics depend largely on the blowing agents, which have a conductivity lower than air;
90% of the cells are closed cells, so the diffusion of the gas out, and its replacement by air, is very slow;
the insulation values quoted by manufacturers are at 25 years, though the boards are expected to last 60 years;
there is a graph which shows that the thermal conductivity increases fractionally from 0.023 to 0.026 over the first three years, and then stays more-or-less constant.
But who knows?; they would say this, wouldn't they!.
