I was always under the impression that I only needed to use inserts for going into conventional compression couplings - and not for plastic pushfit couplings. But.............I am about to do another project in the house and wanted to check "to be sure" but MANY years back when I installed the showee, it was used with no inserts where it went into a pushfit 90 degree bend.
I guess I am just lucky, but after some 14-15 years, it's fairly consistent luck.
I think the bit which irritates now is that all the different manufacturers use different inserts - and claim you can only use theirs on their pipe. this doesn't help when a lot of pipe has no identifying marks and you want to retrofit.
I admit I hadn't intended on doing MUCH to the shower pipe but the 90 degree bend I could get access too without too much drama. I was happy to pop a couple of inserts in - but how do you work out what manufacturer made the pipe?
As a fall back position (very tempted to work on the "if it ain't broke don't fix it policy), would any insert that fitted snugly "do" - or is there truly some weird difference between inserts other than what colour they are?
Mark
Mark
