clf-gas said:Yes some do![]()
timmy74 said:do the ones with fibre washers always leak or is it just to me![]()
It isn't just you - it also happens to all the builder of all the houses where I go to replace the crushed, twisted, mangled and pulped fibre washers.timmy74 said:do the ones with fibre washers always leak or is it just to me![]()
Well, (a) no, and (b) it isn't called a compression connector, because it seals with a washer onto the flat part of the tap tail end.michb said:i guess what TEMPO is asking is do you need to use ptfe on the compression part of the connector to the tap.
