Indeed, but still an eyesore - so only really done by those not prepared to pay for the wiring to be done properly (cables hidden - in walls, below floors, above ceilings etc.).ah yes so thats what mini trunking is so like a tidy for all the wires.
You'd need to ask a lawyer - I'm not sure whether there are any conventions, either as regards 'ownership' or 'rights to use'. It's well over 40 years since I last lived in a flat, so it's not really something I've needed to know about!So who owns the floor/ceiling void between two rented flats?
That's always (I would say always) the case in my experience even if the flats have different owners.Judging by the OP's pic, in his case there seems to have been 'common use' of the void, since there are, or have been, cables going through the void both to above the flooring and below the ceiling (presumably different flats).
Yes, unavoidable without lots of mini (or not so mini) trunking or something equally aesthetically unappealing.That's always (I would say always) the case in my experience even if the flats have different owners. Unavoidable, I suppose.
Indeed, but I don't think there has been any suggestion that the OP intends to do any work on anything - either his flat or the one below. He has said that (on the basis of an inspection) he is happy with the safety of his flat's electrical installation, but is concerned about the wiring of the flat below (under his floorboards), and hence asked ...I was hinting too that there may be legal ramifications to doing work on a rented property without permission. Of course the OPs flat may not be rented, but doing work in the common space would still involve negotiation with someone.
... which sounds like a perfectly correct and appropriate approach to me.These wires are bugging me. Is it illegal to have this old wiring as it may pose as a safety risk? Should I ask the landlord who rents the flat downstairs if he has had an electrical safety check?
What else can they do?Also their water pipes are running through my kitchen and bathroom cupboard.
It would presumably have been done when the building was built or converted and been like it when you bought it.I don't remember signing anything in regards to this.
You may not have signed anything specific, but there could well be Covenants in the Land Certificate (or Deeds) and/or the Sale Contract which you will have signed.I don't remember signing anything in regards to this. I'm an owner and have a share of the freehold, so the owner renting it out has the same and guessing the void underneath is both our responsibility.
Well he was planning originally to push insulation into the void. So there was a suggestion...but I don't think there has been any suggestion that the OP intends to do any work on anything - either his flat or the one below.
