My bath water supply pipes are connected to the water by means of plastic pipes with inbuilt valves.
After changing a dripping tap valve I cannot turn the hot water back on as the small plastic screw in the pipe connector appears to be lodged and I am worried that further attempts may make it impossible to turn on the hot water again.
Does anyone have any suggestions re turning the screw and also if all else fails how much a plumber should charge to replace the small push on pipe connector with the valve in it?
_____________________________
Moderator
please see item 9
Moderator
please see item 9
