in a few months i will be having a boiler installed on my garage wall. on the opposite wall i have all my other pipes from upstairs and downstairs rads, also the cylinder will be located here along with the 3 port valve, shower pump etc.
my garage floor is being concreted on friday 150mm thick, i was going to rn plastic pipe speedfit under the floor up the wall to where the boiler will be. Am i right in thinking this will be better to try and avoid air locks rather than going up across then down the wall to boiler?
if im ok to run in floor shall i just put pipe in insulation and burry? I ahve conduit pipe for the speedfit but this will not insulate the pipes that well will it/ thanks Steve
