Putting up a vapour barrier in humid weather
24 Mar 2014
Hello
I am putting inside insulation on a new house and so far have put up 140mm wood fibre board but the weather is varied there is some rain although in between as I am in France it is fairly warm. But there is a fault with one window which is going to have to be replaced a pvc window. I am not sure if it is okay to begin the vapour barrier layer when the wood fibre may get moisture in with the window change and that could be sealed inside. Is it better to wait until the window is done and the weather dry to put on the vapour barrier? Thank you Carol x
