Puzzle
14 Feb 2007
London
I had the electrics installed about 3 years ago. Whole house was done. Last night everything was working fine. This morning, there is no power to any sockets in the dining room or the lounge area. All other sockets are fine. The trip has not gone off...so just wondered what this could be...i am assuming if it was a dodgy socket the trip would go off...(this has happened before) but this time nothing...trips are all fine. Only thing is there is some works going on outside..water meter being installed but i fail to see a connection...any ideas?
How many MCBs are there in your consumer unit? What circuits and sockets does each control? have any of them tripped?
If not, you have one or more wiring faults.
JohnD
There are 7 in total MCB's. The downstairs sockets barring the kitchen are on there own ring. All the switches look fine...but if there was a fault in the wiring...wouldn't the MCB flip?
if you had a loose or burnt connection, or two, then no. there would be no overcurrent or short circuit to trip the MCB. But connection would be lost. If some of the sockets on the circuit are working and some are not, then it is quite likely a bad connection inside a socket. If they are on a ring then you have at least two faults. It might also be cable damage, typically from a nail or screw in a wall piercing a cable (this can be very dangerous)
Do you feel confident to trace the fault yourself? Have you got a multimeter? (if not, go up to the high street and buy one. it should cost £10 or less)
You will also need a medium and a small electrician's screwdriver, and probably a couple of metres of green and yellow sheathing which you will find in the electrical tools section.
If you are not confident to trace the fault yourself, ask around friends and neighbours for a recommended local electrician. Before asking one to come round, ask if he is a member of a self-certification scheme; which one; how long he has been a member, and what trading name he is registered under (this enables you to check his credentials). this is not a foolproof way of finding a good electrician, but it is a good start. If he is not qualified to self-certify then he is probably not a good and up-to-date domestic electrician.
