Photo voltaic systems
Im not working on one ! just wondering how they work
Would some one please give me a simple break down of the wiring of a PV system at the AC side
Im unsure what is going on in the fuse board.
As I understand it power is generated at the panel
Goes through a DC isolator
Through an inverter
Through a generation meter
through ab AC isolator
Into the consumer unit - where the generated power can be used around the home
Out through the utility meter - where you put electricity 'back in'
Sorry for such basic questions but
How is the PV power wired into the CU
Reading about it I see it goes into a spare way on the consumer unit.
So there fore you have two live feed coming into the board
I don't get this bit
If you plug a generator in you need to use a change over switch. so you are not feeding the grid ?
How can you have any isolation on the supply side?
All I see on the wiring diagrams are isolators for maintenance.
I must have this wrong, or completely misunderstand it.
Through an inverter
