PVC conduit run
6 May 2011
Will be fitting the cables into the PVC with many bends, some 'runs' only 3 inches due to cement pillars and lintels. The local codes, probably very similar to UK, specify number and size of permitted cables in conduit of certain size given the length of run and number of bends (90*). Thus for a run of 3 meters with 3 bends in PVC diameter of 25mm, with cables of 2.5mm i am permitted 12 cables only. My Q. can i install a connection box of some kind, join the cables in the box and start a 'new run' beyond the box for another 3 m? If yes, then i can use fewer conduits to house the cables.
