Need to install 3 outside lights. I appreciate that SWA cable is the best option the problem is that there is very little room in the base of the pedestal lamps to bring in SWA and install a suitable jointing box. as there will be 2 incoming SWA cables and the lamp cable at two of the lamps. Could I install PVC and T&E if the conduit is buried at 50cms, warning marker cable is wrapped around full length, only straight, glued PVC conduit couplings will be used, the conduit will bent 90 degree fittings will not be used. Where the conduit exits the ground underneath the lamps it will be sealed to stop water / condensation ingress. The cables will be joined in a wagobox which will be sealed with silicone once terminations are complete. There is an RCD in the consumer unit that protects all circuits.
Thanks in advance
Mal
Thanks in advance
Mal
