PVC Door Frame
18 Jan 2010
Yorkshire
I have just bought a PVC door frame from B&Q.
The problem I have is that the door frame is slightly too big.
Can you cut a PVC door frame too size?
Its common practice to cut the ribs off around the edge, this should give you 10/12mm, if you need more then it means cutting so much off you end up exposing the chambers, although not the end of the world its not the done thing. How much too big is the door?
